Date/Time: Tue, 26 Nov 2024 02:40:33 +0000
Chart problems again
View Count: 188
[2024-01-08 20:56:26] |
sdeinlein - Posts: 13 |
Hello, unfortunately I have the same problem as on 21.07. The volume profile of the S and P 500 is not displayed separately for each day. There is only one. I have already switched to multiple charts based on fixed time. unfortunately I have had no success so far. Unfortunately I can no longer remember. I have attached two pictures. The SandP 500 as it is wrong and the Gold as it should look. Kind regards Simon deinlein |
Gold right.png / V - Attached On 2024-01-08 20:55:40 UTC - Size: 71.92 KB - 47 views SandP500 wrong.png / V - Attached On 2024-01-08 20:55:52 UTC - Size: 75.63 KB - 48 views Attachment Deleted. |
[2024-01-09 18:11:26] |
John - SC Support - Posts: 36286 |
We responded to this in the Account Support Ticket you opened on this topic. Please do not post more than once for an issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
