Date/Time: Tue, 26 Nov 2024 02:46:39 +0000
[Programming Help] - activation cme data
View Count: 217
[2024-01-08 20:19:59] |
User563586 - Posts: 1 |
I have a problem with activating cme data with package 11. My account is managed as professional, but I should have a non professional one. Could you give me instructions on how to solve it |
[2024-01-09 15:56:59] |
John - SC Support - Posts: 36286 |
In order to be considered a "non-professional" for the CME Group, you need to have a live, funded, futures trading account to which you can connect your Sierra Chart software. For more information, refer to the following link: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges When you filled out your agreements for the CME Group, you entered an Account Number, but you did not enter anything for the Clearing Merchant. If you do not know who your Futures Clearing Merchant is, then enter your Brokerage name where you have your account. You need to redo the agreements at the following link with this information: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
