Date/Time: Fri, 18 Oct 2024 04:08:37 +0000
API - Interactive Brokers
View Count: 301
[2024-01-08 12:47:07] |
Boris Libman - Posts: 58 |
I've been using Interactive Brokers API through SC for some time. Until middle of last week all was working fine. Since last Thursday, I am continually experiencing issues where the position & DPL in chart trade window is displayed incorrectly. Case in point this morning - I had 2 flat to flat trades (came into the day without a position) and it appears that the fills from this morning are being matched up from trades from Friday. How do I begin to troubleshoot this?
[2024-01-08 18:11:35] |
John - SC Support - Posts: 35333 |
Refer to the following: Help With Daily Profit/Loss Value For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-08 19:27:01] |
Thank you for suggesting the p/l value help - I believe the issue is with picking up the fills and maintaining a stable API connection with IB. Nothing changed in the settings for P/L calculation. How can I troubleshoot the API connectivity?
[2024-01-09 15:21:34] |
You really can not troubleshoot the API. But if you refer to the information we have on Interactive Brokers, you will see that there are continuing issues in this regard: Interactive Brokers Trading Service: Trading Related Issues For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-25 20:18:39] |
I trade both ES & MES contracts in my IB account. The data (fills & p/l) for ES come into SC without a problem, however for MES neither the position nor p/l displays in the chart from which orders were entered. The only way I can confirm that I was filled is through IB-TWS. Is there a symbol setting that needs to be fixed or other way to troubleshoot this?
[2024-06-25 21:30:58] |
Are you using a "Trade and Current Quote Symbol" when trading the MES? In other words, are you viewing the ES and trading the MES?
[2024-06-25 23:00:31] |
No, viewing and trading MES. how do I troubleshoot this?
[2024-06-27 18:02:10] |
Sierra_Chart Engineering - Posts: 16656 |
The first thing is to check for the Position in the Trade >> Trade Positions Window and make sure you see it there.
