Date/Time: Tue, 26 Nov 2024 02:34:07 +0000
HEDGING mode
View Count: 229
[2024-01-08 10:57:40] |
User651547 - Posts: 59 |
hi. have you HEDGING mode in sierra ? can i open short and long on the same future ? if yes , how i do it ? if no , how i can do it ? |
[2024-01-08 15:17:51] |
Sierra_Chart Engineering - Posts: 17179 |
No, this is not supported. Refer to: Trading Information Windows: Only Single Consolidated Position Maintained and Displayed per Symbol and Trade Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-01-08 15:22:27
