Date/Time: Tue, 26 Nov 2024 02:41:06 +0000
Can't close Configure Button Window
View Count: 171
[2024-01-08 09:37:41]
User251043 - Posts: 46
I'm using version 2580. I right click on the Control Bar and choose "Configure Button" of a CDT button. The "Custom Drawing Tool Settings Window" opens. I can make changes but I cannot close the window. In version 2563 this is not happening (windows are closing with no problem).
Thank you.
[2024-01-08 17:31:05]
John - SC Support - Posts: 36286
We see the issue and will look into it. In the meantime, when you select "OK" on the Customize Control Bar window, both windows will close out.
[2024-01-08 22:49:13]
Sierra_Chart Engineering - Posts: 17179
We will take care of this.
