Date/Time: Tue, 26 Nov 2024 02:46:15 +0000
connexion problem
View Count: 137
[2024-01-08 08:31:40] |
User657339 - Posts: 4 |
i can not connect to sierra i made a payment 71 usd i activate fees... i have an error message when i connect my sierrachart |
[2024-01-08 08:35:42] |
Sierra_Chart Engineering - Posts: 17179 |
For now: To access historical and streaming market data independent from your Trading service. Follow these instructions. Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command: Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service) You can then use the data provided by Sierra Chart independent of your trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-08 17:28:57] |
John - SC Support - Posts: 36286 |
What exactly is the error message you are getting?
