Date/Time: Tue, 26 Nov 2024 02:41:29 +0000
NUMBER BAR CALCULATED VALUES - Display order not changing plus duplicated number
View Count: 213
[2024-01-08 05:11:53] |
User513390 - Posts: 49 |
Dear John -SC Support, You have expired my question, wondering why? I went to the Subgraph Display Order to display the correct order for the following: 1. Total Volume 2. Delta 3. Cumulative Delta Stating in Subgraph Display Order according the the above. Is is said that this Input is a comma separated list of study Subgraph numbers (1, 2, 3, ...) I have 2 issuers: 1. How to use it, (1,) for Total Volume then so on or (1) to display the correct order above. (image attached) 2. As seen in the picture below the is duplicate number. Can you please direct me in the right direction? Please Rodney |
20240106_121059.jpg / V - Attached On 2024-01-08 05:10:50 UTC - Size: 6.88 MB - 52 views 20240106_121155.jpg / V - Attached On 2024-01-08 05:11:13 UTC - Size: 7.1 MB - 48 views |
[2024-01-08 17:26:33] |
John - SC Support - Posts: 36286 |
We have responded to this in the other Support Board posting you made for it. Please do not post more than once for an issue.
[2024-01-10 13:03:57] |
Thank you
