Date/Time: Tue, 26 Nov 2024 02:23:46 +0000
RSI Candlesticks
View Count: 284
[2024-01-08 02:19:56]
User300852 - Posts: 2
Is it possible to view the RSI in candlesticks? Currently its in line format.
Thanks.
[2024-01-08 17:19:41]
John - SC Support - Posts: 36286
RSI is a single calculated value. What exactly do you want to display as the items of the Candlestick?
[2024-01-08 19:45:01]
Hey John,
The value of the RSI at open/high/low/close within certain period of time (based on the chart) to form a candle stick.
Hope that makes sense. Thanks.
[2024-01-09 15:26:54]
The values of the RSI at each point in time are not maintained, so there is not a built-in way to do this.
Your only option would be to create a custom study and capture the RSI value at each of those points in time and then store them off separately in order to create the bar as you want it. Refer to the following:
Advanced Custom Study Interface and Language (ACSIL)
List of Third Party Sierra Chart Study and System Programmers
[2024-01-09 17:47:38]
Sierra_Chart Engineering - Posts: 17179
You can do this with this study:
Study Overlay - OHLC (Open, High, Low, Close)
