Date/Time: Tue, 26 Nov 2024 02:40:32 +0000
Data Feed
View Count: 137
[2024-01-07 17:28:04]
LaithGs - Posts: 2
What package(s) would i need to get in order to recieve the following:
1. Numbers Chart for the below
2. Live data for indicies, specifically, NAS100 (With accurate volume information)
3. Live data for Forex, XAUUSD
[2024-01-08 16:57:48]
John - SC Support - Posts: 36286
In order to be able to use the Numbers Bars or Numbers Bars Calculated Values (which we assume that is what you are referring to by "Numbers Chart", you need to be on one of the "Advanced" packages.
If you are just needing data for FOREX and CFDs, then this data is available free of charge with any Sierra Chart package. So you could use the "Base Advanced" package for this.
Refer to the information on the packages at the following link:
Description of Service Packages and Pricing: Packages
