Date/Time: Tue, 22 Apr 2025 07:16:53 +0000
[Programming Help] - Add time period option to Swing High and Low study
View Count: 233
[2024-01-07 00:15:10] |
User625582 - Posts: 6 |
Hello Support, Would it be possible to add 'time period type' and 'time period length' along with 'Use User Entered OHLC Values' for where to draw the line after identification of the swing high or low to the study? Kind of similar to what you did on the pivot points -variable period study. This will allow the ability to see higher time frame resistances/supports from within the shorter timeframe. So for example, i can be trading in the 5 min but will be able to see that we are approaching an hourly pivot level. It will also be nice after the identificatin of this pivot to be able to place the line at say the open of that swing high candle rather than the absolute high using the user entered OHLC values. This is invaluable. Thanks. |
[2025-01-27 19:58:17] |
helllo...did anybody get a chance to look into this? thanks.
