Date/Time: Tue, 26 Nov 2024 02:35:09 +0000
1Hr Vbp on a 5min chart
View Count: 177
[2024-01-06 16:51:30] |
hdanng221 - Posts: 6 |
Hi, Is it possible to put a 1HR vbp on a 5min chart? If so, can you direct me to a link for directions? Thanks! h |
[2024-01-08 16:28:45] |
John - SC Support - Posts: 36286 |
Yes, this is not a problem, as long as you have enough data in the chart. Refer to the following: Volume By Price Study: 1 Hour Volume Profile At End of Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
