Date/Time: Mon, 25 Nov 2024 23:38:07 +0000
Delta (AskVol-BidVol) values Above/Below Numbers Bars
View Count: 377
[2024-01-06 11:04:33] |
Jimmyy - Posts: 221 |
Is it possible to display the AskVol-BidVol values of the candle above the number bars if the candle is green and below the number bar if the candle is red and it should also switch places in real time if the candle changes from green to red and vice versa. I am uploading a screenshot for your reference of how it is in one of the platforms I use. Thank you. Date Time Of Last Edit: 2024-01-06 15:13:48
Screen Shot Sat 01 6 2024 at 4.33 PM.png / V - Attached On 2024-01-06 11:03:58 UTC - Size: 82.59 KB - 96 views |
[2024-01-08 16:42:25] |
John - SC Support - Posts: 36286 |
Yes, this can be done, but the account you have posted from is expired. If you are using another account, then please post in this thread letting us know that you have logged in with your active account. Otherwise, we do not give support for non-active accounts.
[2024-01-12 18:37:30] |
I am now subscribed. Can you now please tell me how could it be done? Thanks |
[2024-01-12 21:51:34] |
Attached is a Study Collection that does what you are asking. Refer to the following for how to use this: Study Collections: Using a Study Collection Provided by Sierra Chart Support For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-01-12 22:15:04
DeltaAboveBelowBarBasedOnUpDown.StdyCollct - Attached On 2024-01-12 22:14:59 UTC - Size: 73.81 KB - 153 views |
[2024-01-12 22:15:32] |
The previous post was updated with a new version of the study collection, as there were a few items that needed tweaking.
[2024-01-26 14:37:04] |
Hey, I just tried to use this study and it seems to be working fine. But is it possible to remove the decimal ".00" values ? Thanks
[2024-01-26 17:07:19] |
Set the "Value Format" for the study for which you want to remove the data after the decimal point, to "1". Refer to the following: Chart Studies: Settings and Inputs Tab >> Value Format For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
