Date/Time: Tue, 26 Nov 2024 02:47:09 +0000
Charting Scale
View Count: 207
[2024-01-06 03:02:08] |
YAG86 - Posts: 12 |
HI SC team, I have cumulative delta on chart region 1 along with the price as well. is there a way to scale them independently? My goal is to scale either the price or the cumulative delta to align with the other as much as possible. right now I have price in interactive scale and the cumulative delta to constant range within the study settings scale. |
[2024-01-08 15:36:02] |
John - SC Support - Posts: 36286 |
Set the Cumulative Delta scaling to be "Independent" and enable the option for "Use in Left Side Scale". Then turn on the Left Side scale and you can then adjust the scaling independently. Refer to the following: Chart Scale and Scale Adjusting: Use In Left Side Scale Chart Settings: Use Left Side Scale (Chart >> Chart Settings >> Scale menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-10 00:28:07] |
YAG86 - Posts: 12 |
THANK YOU very much! this is exactly what I was looking for!! much appreciated
