Date/Time: Wed, 27 Nov 2024 04:46:43 +0000
two questions..
View Count: 1139
[2014-07-30 11:49:02] |
User30743 - Posts: 365 |
hi, i got two things here to discuss with you. 1) i use orderflow charts in my chartbook and the numbers in there are at different size - for example for the market NQ the numbers are quite big sized - http://www.sierrachart.com/image.php?l=1406720512650.png , for the chart TF the numbers are little bit smaller - http://www.sierrachart.com/image.php?l=1406720586679.png . i would prefer them to be smaller as it is in the TF market, because i have a small monitor, but i havent found where to set up the size of the numbers. i have never set it up and it kind of a mystery for me that TF orderflow chart has smaller size then NQ. could you tell me how to change the size? 2) is there a way to play on SIM mode but make the charts/chartbook look like if it were real? i mean, there is a small line saying [Sim] at every left corner and te upper bar, and i wonder if it is possible to hide it somehow Date Time Of Last Edit: 2014-07-30 11:50:01
[2014-07-30 16:51:59] |
1. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#Font 2. No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-02 08:57:55] |
ok then, back to question no.2 - is it possible to at least hide the daily profit/loss? i tend to do stupid things when i see i am in a nice profit. it would be better for me not to know it :-)
[2014-08-04 11:11:47] |
Uncheck Global Settings >> Chart Trade Settings >> Display Daily Profit/Loss.
