Date/Time: Tue, 26 Nov 2024 03:42:30 +0000
The remote build did not succeed. Result: No result text was given.
View Count: 318
[2024-01-05 23:07:55] |
ray42 - Posts: 21 |
Hi, Remote builds are not working. Is there an issue on Sierra's side? This exact same code (tracked using git) was compiled without any issues the day before yesterday. This is what I see now: -- Starting remote build of Custom Studies Source files: [FILENAME].cpp. 64-bit -- 18:04:04 Allow time for the server to compile the files and build the DLL. The remote build did not succeed. Result: No result text was given. -- End of Build -- 18:04:05 Can a sierra staff reply, please? Thank you |
[2024-01-06 10:41:58] |
Sierra_Chart Engineering - Posts: 17179 |
We need some time to look into this.
[2024-01-06 21:22:30] |
sprte1 - Posts: 7 |
I had this problem yesterday as well. Remote Build seems to be working fine now. |
[2024-01-06 21:57:11] |
Yes it was resolved earlier today. As an alternative, use the Visual C++ compiler which can be installed from Build >> Install Visual C++ Compiler from the Build Custom Studies window.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-01-06 21:57:51
