Date/Time: Wed, 27 Nov 2024 04:55:50 +0000
How can I change Chart time fram to 2min or 3' ?
View Count: 1169
[2014-07-30 11:07:56]
User402474 - Posts: 5
Dera Sirs,
Sierra Chart is really good , but i miss the possibility of Change time Frame of Chart to 3', or 2' . Is it possible ?
[2014-07-30 16:11:35]
Yes it is. Refer to the documentation here:
http://www.sierrachart.com/index.php?page=doc/doc_KeyboardCommands.html#Period
[2014-07-30 16:14:47]
User48557 - Posts: 138
Right click your mouse on the chart you want changed. Then click "Chart settings" . Once on that screen you will see 0-1-0 near the middle of the screen. That represents days-minutes-seconds. Change those numbers around to the chart type you want.
