Date/Time: Tue, 26 Nov 2024 03:56:24 +0000
Chart Trade Panel
View Count: 246
[2024-01-05 04:59:30]
User524616 - Posts: 15
See the attached image. I am in SIM mode trading Micro Contracts.... MNQ, but the trade panel is showing NQ prices in the PL and DPL.
I await your assistance on how to correct this.
imageSierra Support.jpg / V - Attached On 2024-01-05 04:55:24 UTC - Size: 223.93 KB - 62 views
[2024-01-05 16:53:28]
John - SC Support - Posts: 36286
You need to look at the setting for "Chart >> Chart Settings >> Symbol >> Currency Value per Tick". It should be 0.5 for MNQ, but it looks like it is set to 5.0
[2024-01-05 17:44:42]
was working fine before i used the replay chart. I made a new chart and copied the studies over... its okay now... thank you
