Date/Time: Tue, 26 Nov 2024 04:02:13 +0000
DOM
View Count: 173
[2024-01-05 01:26:46] |
User674078 - Posts: 2 |
How do I add difference between ask volume and bid volume (delta) column to my DOM?
[2024-01-05 16:36:18] |
John - SC Support - Posts: 36286 |
There is not a column for "Ask Volume - Bid Volume". You would have to use the Volume by Price study to get this information for the time period you are interested in. You can right-align the profile to be next to the DOM, essentially turning it into another column, just always in one position. Refer to the following: Volume By Price Study: 1 Day Total Volume with Bid Ask Delta on Right For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
