Date/Time: Tue, 26 Nov 2024 03:30:21 +0000
Alert For Numbers Bars Calculated
View Count: 179
[2024-01-05 01:25:32]
thaundadogfx - Posts: 4
In need of help, I wanted to create a simple alert, that would alert me when there is a certain threshold met when calculating the delta in each bar. I see that the study uses color coordination according to the amount of threshold that has been reached. Not sure if I'm explaining this correctly but in the settings of the numbers calculated study I would like for an alert to go off for Range 2 and 3. The attached file shows an arrow pointing to the type of alert I'm trying to accomplish.
imageGBPJPY[M] 15 Min #6 2024-01-04 19_19_52.236.png / V - Attached On 2024-01-05 01:22:41 UTC - Size: 167.83 KB - 52 views
[2024-01-05 16:33:49]
John - SC Support - Posts: 36286
There is not a direct way to get an alert based on the color. You need to review the information for how the coloring is done and then you can create an alert based on the data. Refer to the following:
Numbers Bars: Calculated Values Background Coloring Logic
