Date/Time: Tue, 26 Nov 2024 03:31:48 +0000
Clearing data on DOM
View Count: 216
[2024-01-04 23:08:07] |
countryboy92 - Posts: 91 |
I like to clear: Recent Bid/Ask Volume, Current Traded Bid/Ask Volume and Pulling and Stacking Data all at the same time. Is there a way to do this without having to click on each one separately? In other words, can you clear all data with one click?
[2024-01-05 16:02:09] |
John - SC Support - Posts: 36286 |
There is not an option to clear them all with one click. Just the separate options to clear them. You could create a custom study to do this and assign it to a control bar button. Refer to the following: sc.ClearCurrentTradedBidAskVolume() List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
