Date/Time: Tue, 26 Nov 2024 04:01:05 +0000
Dom and clear current traded bid/ask volume
View Count: 188
[2024-01-04 21:37:30] |
User862183 - Posts: 2 |
French : Bonjour, J'ai un problème avec les carnets d'ordres de sierra chart, j'ai que carnet identique pour le même marché (Nasdaq), lorsque j'appuie sur "clear current traded bid/ask volume" du premier carnet cela marché correctement mais le problème que je rencontre est qu'il le fait aussi sur le 2eme carnet alors que je voudrais qu'il ne le fasse que je celui que j'ai cliqué, c'est à dire le premier. Si quelque aurait une solution, ça m'aiderait beaucoup, merci. English : Hello, I have a problem with the sierra chart dom, I have that identical dom for the same market (Nasdaq), when I press on "clear current traded bid/ask volume" of the first dom it works correctly but the problem I encounter is that it also does it on the 2nd dom while I would like that it does it only the one that I clicked, ie the first. If anyone has a solution, it would be very helpful, thank you. |
dom sierra chart bug.png / V - Attached On 2024-01-04 21:34:03 UTC - Size: 137.89 KB - 55 views Attachment Deleted. |
[2024-01-05 15:47:21] |
John - SC Support - Posts: 36286 |
There is not a solution to this. You are clearing the information for the symbol, therefore any other chart using the same symbol will also get cleared. The only solution would be to use a Sub-Instance, which then creates a completely independent instance of Sierra Chart. If you clear the Current Traded volumes in one instance, it will not impact the other one. Refer to the following: File Menu: New Instance (File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
