Date/Time: Tue, 26 Nov 2024 04:23:40 +0000
Copy chart drawings from Chartbooks
View Count: 265
[2024-01-04 19:13:03] |
Technical - Posts: 158 |
With Sierra Chart documentation I have successfully duplicated hand drawn lines from one chartbook to another (in the same instance) by referencing the chart book within the chart settings. as in: Chart>>Chart Settings>> Chart Drawings>>"Copy chart drawings from chart #'s" Ref: Copying Chart Drawings from Other Charts Automatically: Copying Chart Drawings from Other Charts That works. Thank you. However, when I use a study or spreadsheet to draw lines on the reference chart, those drawings are ignored by the function listed above, "Copy chart drawings...". Is it a draw-style issue within the subgraph? How can Sierra automatically copy drawings, regardless of the source, Spreadsheet, Study or hand-drawn? Date Time Of Last Edit: 2024-01-04 19:21:43
[2024-01-04 22:31:31] |
John - SC Support - Posts: 36286 |
Studies (including the Spreadsheet Study) use a different mechanism for drawing. These are very different from the items that are drawn using the items under the Tools menu. It is these drawings (Tools) that are the ones that are copied using the method you referenced. In order to copy study information, you need to use the "Study/Price Overlay" study. Refer to the following: Study/Price Overlay Study But, it is not possible to overlay the study information between chartbooks. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
