Date/Time: Tue, 26 Nov 2024 04:45:37 +0000
Charts in Chartbook dissappeared
View Count: 188
[2024-01-04 17:37:22]
Ktrades07 - Posts: 4
Hey all
The charts in my chartbook have disappered and when I try to restore the windows nothing it there.
Is there a way to retrieve an earlier version of a chartbook? Or something else I could try to retreive the charts?
Thanks,
Kyle
imageScreenshot 2024-01-04 at 6.30.00 PM.png / V - Attached On 2024-01-04 17:34:59 UTC - Size: 53.72 KB - 48 views
[2024-01-04 18:42:28]
John - SC Support - Posts: 36286
To start, select the "CW" menu at the top and see if the charts are simply not showing. Any charts in the chartbook will be listed there, and you can select them to bring them up.
If you still do not have the charts, then refer to the following for how to access backups that are made of your chartbooks:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
