Date/Time: Tue, 26 Nov 2024 04:21:33 +0000
Study Data Not Showing In Spreadsheet
View Count: 268
[2024-01-04 16:35:45]
PolandSpringer - Posts: 30
I am using the "Spreadsheet system for trading" and a moving average study on my chart. "Include in spreadsheet" on both the main settings page as well as the subgraphs page are selected in the moving average study.
I have also tried moving around the order of studies, but I cannot get moving average data to appear on the spreadsheet
[2024-01-04 18:28:56]
John - SC Support - Posts: 36286
Is the Moving Average hidden, or is the subgraph set to Hidden or Ignore?
Do you have other studies on the chart, and are those showing in the Spreadsheet?
[2024-01-04 19:08:12]
I have resolved the problem, I wasn’t looking at the entire spreadsheet. Data for the studies was pushed all the way to the right.
Thank you for the prompt response anyways
[2024-01-04 22:25:32]
Yes, the studies show up after the "Calculation Columns" which is a number that is controlled through the Inputs on the Spreadsheet Study. The default is 16, which means that the study data starts at column AA.
