Date/Time: Thu, 19 Sep 2024 01:19:11 +0000
access tick by tick in bar chart
View Count: 1096
[2014-07-30 03:47:18] |
maxpi - Posts: 180 |
Can acsil code access tick by tick data when running on a chart that is displaying for example 1 minute, or 500 ticks per bar?
[2014-07-30 04:03:32] |
One thing can do is read the individual tick by tick data from the Intraday data file: https://www.sierrachart.com/index.php?page=doc/doc_IntradayDataFileFormat.html Also, refer to this ACSIL function member: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scGetTimeAndSales Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
