Date/Time: Tue, 22 Apr 2025 18:33:47 +0000
Symbols from EURONEXT
View Count: 310
[2024-01-04 11:50:31] |
User584849 - Posts: 1 |
Dears, I am unable to find any symbols from EURONEXT in the Sierra Chart symbols library. Could you please provide guidance on how to access the European stock markt symbols in Sierra Chart. Thansk in advance for the support. Fernando da Silva |
[2024-01-04 16:42:58] |
John - SC Support - Posts: 39418 |
We do not have real-time data for EURONEXT. But if you want delayed data (it may be as much as 1 day behind), then you can get this through us. Our server show that your "Current Selected Service" is "SC Data - All Services", in which case if you select "File >> Find Symbol" you will see a section for "Futures - Euronext". Open that section to see what we have available. Or you can use that format and see if another symbol might be available (anything not listed may or may not be available). This data comes from a 3rd party provider, which is why we can not give specifics on what you can get. It just depends on what they have available. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-29 15:12:32] |
stephane1 - Posts: 112 |
Hello John, what's the best way to use in same time "real time data" euronext nyse and nasdaq equities .. thank you
[2024-10-29 16:09:30] |
Where do you plan to get your EURONEXT data from? We do not have real-time data for this.
[2025-01-02 20:08:30] |
Hi there, Please!!! My opinion you'r a best platform... Could you please offer european equities in real time ? Lot of European trader need professional platform like SC ... tku |
