Date/Time: Tue, 26 Nov 2024 04:36:12 +0000
account defining
View Count: 156
[2024-01-04 11:37:55]
User660392 - Posts: 44
Hi
I am a non professional trader so i ask my account will be defined as a non professional trader.
second , how much should i pay for getting CBOT & CME REAL TIME DATA as non professional trader?
Third, i receive a non stop massage log .
Tnx.
[2024-01-04 16:37:22]
John - SC Support - Posts: 36286
In order to be considered a "Non-Professional" for the CME Group, which allows you to get the real-time data at a much better price, you need to have a live, funded, futures trading account to which you can connect your Sierra Chart software for verification. Refer to the following for more information on this requirement:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
If you do not have an account that meets the requirement, then we recommend the solution outlined at the following link:
Easy Solution to CME Funded Trading Account Requirement
Once you have the above worked out, then as you go through the Setup Instructions at the following link, be sure you enter the [Futures] Clearing Merchant (or broker if you do not know your FCM) and your account number in the Uniform Subscriber Agreement. Without this entered, we can not set you as a non-professional.
The pricing for the exchanges is at the following link:
Denali Exchange Data Feed: Supported Exchanges (Exchange Fees)
What exactly is occurring with your Message Log?
