Date/Time: Tue, 26 Nov 2024 04:19:53 +0000
DATA
View Count: 158
[2024-01-04 11:11:09] |
User611446 - Posts: 1 |
HI DEAR i can not get any data on my chart before I was in Turkey I used another account now I am in travel in Iran and I don't know why I cannot get data while I am connected to the server is this related to my location? pls check the attached file to clarify thanks |
Attachment Deleted. 2024-01-04_14-39-42.png / V - Attached On 2024-01-04 11:10:18 UTC - Size: 246.15 KB - 52 views 2024-01-04_14-32-28.png / V - Attached On 2024-01-04 11:10:27 UTC - Size: 213.08 KB - 51 views |
[2024-01-04 16:32:54] |
John - SC Support - Posts: 36286 |
You are getting a "Windows Error 10053". Refer to the following regarding this: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
