Date/Time: Wed, 27 Nov 2024 04:57:36 +0000
Keep Rectangle Text on Top
View Count: 1161
[2014-07-30 02:33:26] |
OneMoreTick - Posts: 79 |
Please see attached screenshot. There are 2 rectangles on top of each other and there's text associated with the bottom rectangle but it's hidden by the top one. How can I get the text to stay on top and be visible?
[2014-07-30 03:31:54] |
Is that text drawn with the Type Text tool? In any case, there really is not much that can be done other than to delete it and to retype it again so it will be on top of the other drawings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-30 03:44:57] |
It's not from the type text tool, it's the text that's linked to the rectangle drawing.
[2014-07-30 03:46:46] |
Ok, I copied the rectangle and the copied one's text shows up on top of the other rectangle. It seems that whichever one is created last gets precedence.
[2014-07-30 04:04:32] |
Yes, this is correct.
