Date/Time: Tue, 26 Nov 2024 04:18:09 +0000
Seeing more Numbers Bars Data on a single screen
View Count: 144
[2024-01-03 20:24:02] |
User131038 - Posts: 1 |
You can see in the attachment (ScreenShot - 1) the Numbers Bars are visible but I don't even capture a full 30 minutes of data without the bar being cut off & in the other (ScreenShot-2) it captures the full bar but the Number Bars are not visible -- being too small. Anything I can do to see more bars on a single screen?
Screenshot - 1.png / V - Attached On 2024-01-03 20:23:47 UTC - Size: 163.82 KB - 53 views Screenshot - 2.png / V - Attached On 2024-01-03 20:23:57 UTC - Size: 146.68 KB - 51 views |
[2024-01-03 21:47:20] |
John - SC Support - Posts: 36286 |
This is the tradeoff that you have to deal with when using Numbers Bars. You have to find the right combination of bar period and scaling that works for you. There is no magical answer here. Refer to the following for how to make adjustments: Numbers Bars: Scaling a Numbers Bars Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
