Date/Time: Tue, 26 Nov 2024 04:45:50 +0000
URGENT -- Session settings
View Count: 170
[2024-01-03 16:21:28] |
User472677 - Posts: 350 |
VERY TROUBLING -- URGENT I am long time sc customer. I need your help to urgently resolve this very troubling situation. Yesterday, I took time to manually change all 100 charts to show evening session and to not start a new bar at the session open. I saved all and exited. This morning when I restarted sc, it did not show pre session data. I again manually changed settings to show pre session data. At 9:30, all pre session data disappeared and a new bar started. I want settings to hold even when a symbol is changed. Please contact me to log on and fix this or tell me exact settings to change |
[2024-01-03 17:11:20] |
John - SC Support - Posts: 36286 |
In order to have those settings the way you want when you change symbols, you need to change the "Symbol Settings" for the symbols you are going to be using. Refer to the following: Global Symbol Settings: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
