Date/Time: Tue, 26 Nov 2024 04:23:09 +0000
CQGWEBPI LOGON UNSUCCESSFUL(MY SERVICES GOT DEACTIVATED DUE TO UNSUFFIENT FUND)ACTVATED
View Count: 203
[2024-01-03 00:32:30] |
Anaya2603 - Posts: 2 |
https://www.sierrachart.com/image.php?Image=1704241672874.png
[2024-01-03 02:48:49] |
Sierra_Chart Engineering - Posts: 17179 |
Regarding this, see number 12 here: CQG Trading Platform Service: Common Error Messages In the meantime: To access historical and streaming market data independent from your Trading service. Follow these instructions. Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command: Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service) You can then use the data provided by Sierra Chart independent of your trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
