Date/Time: Tue, 26 Nov 2024 04:46:25 +0000
Playback
View Count: 157
[2024-01-02 21:40:58]
User143052 - Posts: 34
When I start a playback my screen goes black. I can see one bar at the far left side of the screen.
imageScreenshot 2024-01-02 152559.png / V - Attached On 2024-01-02 21:31:43 UTC - Size: 46.2 KB - 55 views
[2024-01-02 21:51:38]
John - SC Support - Posts: 36286
Do you have data loaded in the chart that goes back to 2022-09-08 at 10:59:34? If not, then you need to have the data loaded prior to running the replay. Refer to the following:
Replaying Charts: Use Start Date-Time
