Date/Time: Tue, 26 Nov 2024 04:24:35 +0000
Possible create Studies chart in candlestick form?
View Count: 209
[2024-01-02 20:50:04]
gonf85 - Posts: 14
IS that possible to create study ratio between DVOL/UVOL in term of candlestick form(OHLC)?
The symbol I can find is only UVOL/DVOL ratio, so I try to create DVOL/UVOL ratio manually.
But the ratio chart I create only shown line (single data).
imageCapture.PNG / V - Attached On 2024-01-02 20:41:48 UTC - Size: 37.94 KB - 64 views
[2024-01-02 21:20:23]
John - SC Support - Posts: 36286
You would need to use the "Ratio - Bar" study. Refer to the following:
Ratio (Bar)
[2024-01-03 13:36:49]
gonf85 - Posts: 14
This is what I need.
Thank you very much!!!
