Date/Time: Tue, 26 Nov 2024 04:23:09 +0000
Message Log Time Stamps ahead by 7 hours
View Count: 208
[2024-01-01 19:24:26] |
User68474 - Posts: 201 |
Should the time stamps for my Message Logs be out of sync by +7 hours. I'm in Eastern Time Zone, typing at app. 2:20 P.M.; GMT is app.7:20PM.; My Message Log for my last entry to test this was app. 19:20. Is this normal??
[2024-01-01 20:32:37] |
Sierra_Chart Engineering - Posts: 17179 |
The message log is showing times in the UTC time zone which is how they are always internally stored. If you update to the latest prerelease, the times will then be in the Sierra Chart set time zone.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-01-01 20:32:56
[2024-01-01 21:20:01] |
Funny how I never noticed that discrepancy before! I had just downloaded the newest "current" version 2576. I also seem to have "lost" my "Compact Tool Values Window" after that update. Now you want me to go to "Pre-Release"? Happy to do so, but have never, as a practice in the past, used the "pre-release". All just seems a bit goofy since the clock struck in the New Year last night!
[2024-01-01 21:30:05] |
Yes you need the latest prerelease.: Software Download: Fast Update Regarding the Compact Tool Values window, refer to: Chart Drawing Tools: Compact Tool Values Window Not Visible Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
