Date/Time: Tue, 26 Nov 2024 04:17:26 +0000
[User Discussion] - Stop Offset
View Count: 236
[2024-01-01 17:22:11] |
User975578 - Posts: 2 |
Dear Support, First let me wish you a happy NY. I'm struggling to find answers to a simple question. I'm using Average True Range studies and i'd like to configure a Trade window config that can automatically calculate the Stop offset to the value of the ATR at the moment of acting the order. Is it possible? Thanks |
[2024-01-02 15:01:55] |
John - SC Support - Posts: 36286 |
You can not set the Stop offset based on a study. You would have to use the "Trade Management by Study" to do this, but then you would need to turn it off if you want to make a manual adjustment later. Refer to the following: Attached Orders: Study Controlled Targets and Stops For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
