Date/Time: Mon, 25 Nov 2024 20:43:17 +0000
Enhancement suggestion - Sort sim accounts numerical
View Count: 264
[2024-01-01 16:30:36]
User43 - Posts: 101
Hello currently sim accounts are sorted alphabetically
meaning Sim2 comes after sim19
sim1, sim10, sim11, ... sim19, sim2, sim20, sim21, ... sim29, ...
but it would be nice to see them sorted
sim1, sim2, ... sim9, sim10, sim11, ... sim19, sim20, sim21, sim29, ...
Thanks for your consideration
Martin
imageSierraChart_64_l6XOTMjK71.png / V - Attached On 2024-01-01 16:25:50 UTC - Size: 12.49 KB - 63 views
[2024-02-02 05:31:07]
Sierra_Chart Engineering - Posts: 17174
We are checking on this. These accounts should not be sorted like that. The list of Trade Accounts should not be sorted and we will disable it if it is.
[2024-02-02 07:22:48]
User61168 - Posts: 403
Sorting helps as I have over 200+ sim accounts so perhaps the solution is to start account names with 1-sim, 2-sim, 3-sim,...
[2024-02-02 14:07:33]
User43 - Posts: 101
@Sierra Chart Engineering
How should they be sorted?
From your feedback it sounds to me, the sorting I documented in my initial post is not what you expected.
