Date/Time: Tue, 26 Nov 2024 04:50:53 +0000
Email alert never comes
View Count: 216
[2024-01-01 12:41:48]
tomas262 - Posts: 141
hi,
a long-time user here. Used to work well in past. After some time I got back to using Sierra again but now it does not work
The alert (5) is working - that is I hear the AlertSound.wav but the email never comes to my mailbox.
I used to use this heavily and reliably in the past
Running SC 2416 due to Stonex support
Private File
[2024-01-01 23:11:21]
Sierra_Chart Engineering - Posts: 17179
The problem could be with Outlook. But it is not on the list of blocked domains:
https://www.sierrachart.com/index.php?page=doc/BlockedDomains.php
Also refer to:
https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#WhatToDoIfYouDoNotGetAnEMailAlertMessage
We are going to be developing Telegram support, as quickly as possible. Hopefully in about two weeks. So this will be another way to send alerts. This will be a much more reliable means to receive alerts on a mobile device.
Date Time Of Last Edit: 2024-01-01 23:11:39
[2024-01-02 09:02:19]
You're right, Gmail works well, thanks
