Date/Time: Wed, 27 Nov 2024 06:44:00 +0000
Horizontal line at a specific price based on the left scale values
View Count: 1073
[2014-07-29 16:17:42] |
User48838 - Posts: 120 |
I want to draw a horizontal line at zero in Pane 1, based on the indicator i have overlaid on the price bars. Any help on how this line can be drawn? Thanks. |
[2014-07-29 18:03:08] |
Use the "Line" study.
[2014-07-29 20:34:52] |
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=3047 The attached shows what i am doing, with out success, am more help you can give. Thanks |
Private File |
[2014-08-07 08:02:54] |
Really videos are more of a burden to us than help. We are very busy and do not have time to be concentrating on a video. This is the reason why there has not been a follow-up yet. If you post an image of the chart by following these instructions, we will have a better sense of what you may need to do. Here are the instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
