Date/Time: Tue, 26 Nov 2024 04:49:55 +0000
Question on Upgrading to the latest Version of SC
View Count: 198
[2024-01-01 11:18:15] |
User385365 - Posts: 9 |
Thanks! Just activated CME with Market Depth for non-professional Trading accounts. On my original support request I asked if I can upgrade to the latest version of Sierra Charts. I'm running 2383 Rev. 41758 now and have been for the past 2 or so years since my platform would not work after I upgraded so had to go back to this version. D. |
[2024-01-01 20:31:32] |
Sierra_Chart Engineering - Posts: 17179 |
Yes you can update. Instructions are here: Software Download: Fast Update If you have any problems with Chartbook compatibility let us know. There is nothing to be concerned with, because there are backup Chartbooks, and there is a way to make compatibility if there is any problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-01-01 20:31:37
