Date/Time: Tue, 26 Nov 2024 04:48:35 +0000
Number how much Bid/Ask is being hit independent of size
View Count: 233
[2024-01-01 06:34:56] |
RocMarci - Posts: 14 |
Hi, I was wondering if there is a way to display a number how often the bid is being hit/the ask is being hit over a certain period of time(a candle for example), independently of what size it is being hit with. A ratio between the two would be good too. Cheers and Happy new year! Date Time Of Last Edit: 2024-01-01 07:36:50
[2024-01-02 14:28:31] |
John - SC Support - Posts: 36286 |
The only thing we have is a ratio, which is the "Ask Bid Tick Difference (AskT - BidT)" from the Numbers Bars Calculated Values Study. There may be other subgraphs that you would find useful. Refer to the following: Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
