Date/Time: Tue, 26 Nov 2024 04:48:28 +0000
[Programming Help] - Is there a study/method that can remove all negative values from another study's output?
View Count: 231
[2023-12-31 21:51:01]
gjockey - Posts: 48
For example, is there a way to apply a moving average study to only the positive values of a "Ask Bid Volume Difference Bars" study? ie. is there a process or study that can remove the negative numbers from the "Ask Bid Volume Difference Bars" study output so that I can then apply a moving average to the remaining positive only values? Thanks
[2024-01-01 16:52:18]
Sawtooth - Posts: 4120
Try this:
- Add the Spreadsheet Formula study, with a formula like this in its Formula field:
=IF(ID1.SG4>0,ID1.SG4,0)
where ID1.SG4 is the Ask Bid Volume Difference Bars study's Close.
Hide this study.
- Add the Moving Average - Simple Skip Zeros study, 'Based On' the Spreadsheet Formula study.
