Date/Time: Tue, 26 Nov 2024 04:31:03 +0000
TETON and question
View Count: 235
[2023-12-31 19:09:55] |
User402198 - Posts: 1 |
im triyng to connect to AMP futures to create a live account, if i have used DOM, do i need the package 11 or 10 to use the DOM, the volume profile tool. And how does teton work? and do i need to pay for denalli for CME data or it is included in somewhere? I appreciate your help😃
[2024-01-01 16:04:15] |
SC Support - Posts: 1895 |
In order to connect Sierra Chart to your AMP Futures Trading Account (or to activate Real-time Futures Data) you would need to be on one of SP10, SP11 or SP12 >> for you Volume Profile would be available on SP11 or SP12: Description of Service Packages and Pricing: Packages You can convert your SP5 Usage Time into SP11 Usage Time by activating an SP11 option from this drop-down here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#ServicePackage (the conversion ratio is the relevant price ratio) Regarding Teton Order Routing, AMP can put you onto Teton Order Routing Service without Sierra Chart's intervention; when AMP Futures has added you to the Teton Order Routing Service, your set-up instructions begin with step #5 here: Sierra Chart Teton Futures Order Routing: Setup Instructions When it comes to Real-time Stock or Futures Data, the exchanges sell that data each month and for access you would need to be on one of SP10, SP11, or SP12 and even then you would need to pay the corresponding Real-time Data Exchange Fee for what you activate, the cost of Real-time Stock or Real-time Futures Data is not included in the Price of Sierra Chart Software Usage Time. Denali Exchange Data Feed: Supported Exchanges (Exchange Fees) |
