Date/Time: Tue, 26 Nov 2024 04:28:00 +0000
unable to flatten position.
View Count: 267
[2023-12-31 17:47:03]
User373245 - Posts: 42
my log says this and I am trying to flatten my positions at the end of the day? Is there something that has to be checked or unchecked in a spot to be able to flatten positions?
AUDJPY[M] 240 Min #1 | User order entry | Unable to Flatten/Reverse. Position does not exist | Symbol: [Sim]AUDJPY | TradeAccount: Sim1 | 2023-12-31 17:44:55.931 *
[2023-12-31 17:53:03]
I know that it says position does not work...but I am having trouble flattening the positions when its open also and wondering if I have to set this up in a spot
[2023-12-31 21:59:34]
Sierra_Chart Engineering - Posts: 17179
That rejection relates to a simulated position. In the chart you are trading from there is not a position for that symbol.
Are you trying to flatten a position you see in Trade >> Trade Positions Window?
[2024-01-01 00:50:26]
Yes the trade shows up on the chart. Is there a difference in SCDateTime formatting when replaying vs live. The trade initiates correctly and does everything correctly until I try to ad a flatten trade...when I do it it flatten instantly and I was wondering if its somehting in trade setting. As this is for replaying data.
[2024-01-01 20:03:29]
No:
If there is some issue with an incorrectly report position, refer to:
Trading Information Windows: Incorrectly Reported Trade Position Quantity
