Date/Time: Wed, 27 Nov 2024 04:38:35 +0000
Is there an "Opening Range" study somewhere?
View Count: 1145
[2014-07-29 15:47:39]
DarthSidious - Posts: 63
Something that will draw a pair of horizontal lines from session start to session end, with parameters being either a set number of bars since opening (to use on tick/volume charts) or a set number of minutes since opening (for minute charts)?
If not, I will need to write one. But I thought one must exist already, but can't find it...
[2014-07-29 17:11:56]
Use the High/Low for Time Period-Extended study.
[2014-07-29 21:48:08]
Sawtooth - Posts: 4120
You can also use the Initial Balance study.
[2014-07-29 23:12:37]
That's right! Thanks tomgilb, and SC Support of course!
