Date/Time: Mon, 25 Nov 2024 22:52:38 +0000
Data Feed
View Count: 458
[2023-12-31 07:19:21] |
User125782 - Posts: 4 |
Hello, I’m currently using Denali and want to switch to Rithmic data feed. Can you please assist on this matter? |
[2023-12-31 10:23:05] |
Sierra_Chart Engineering - Posts: 17177 |
No, we cannot help with that. We are certainly not going to help create problems for ourselves and lead a user into trouble.
[2023-12-31 17:08:33] |
Is it possible to have a second SC installation routed with Rithmic data feed for a separate account on the same computer?
[2023-12-31 21:11:48] |
Yes of course. Refer to: Using Multiple Data and Trading Services at the Same Time And we may have misunderstood your original question. For our policy regarding Rithmic, refer to: Rithmic Trading Platform Service: Rithmic Market Data and Support Policy We just did not want you to stop using the Denali Data Feed which you are already using, cancel it and then use Rithmic real-time and historical data and have problems. But maybe you are confusing Teton order routing with Denali. Definitely continue to use the Denali Data Feed and use it with Rithmic. You are already properly configured to use the Denali Data Feed and real time CME data and you should continue to do so. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-12-31 21:12:39
[2024-01-04 01:46:06] |
Any instructions on how set up Denali Data Feed (for historical / market data) with Rithmic (order routing)? What are the costs of adding Rithmic? This is for the second SC installation for TopStep account. Note: I do not intend to alter my existing Denali configuration, which use for my personal account. |
[2024-01-04 03:44:42] |
The issue has been resolved.
[2024-01-26 11:18:37] |
User756145 - Posts: 6 |
How to use Denali data while executing via a Rithmic acc ?
[2024-01-26 16:10:49] |
John - SC Support - Posts: 36286 |
Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
