Date/Time: Tue, 26 Nov 2024 04:25:11 +0000
Is there a way to save symbol settings for quick loading on other Data Services?
View Count: 264
[2023-12-31 03:41:06] |
User740504 - Posts: 110 |
I'm using the following Data/Trade Service Settings: Rithmic (TopStep) Trading Evaluator (SC Demo) SC Data - All Services (Backtesting/Automation) Teton CME (Stage 5 Trading) Each service has their own symbol settings with their own session times, commission rates, minimum market by order quantity, and more. Is there a way to save all settings in the "Global Settings -> Symbol Settings" window so I can upload these settings to a new service without having to go through and do it manually by hand for each product? I understand a symbol such as ES can be: ESH24.CME ESH24_FUT_CME ESH24-CME etc. depending on the Data connection, and that the data is explicitly saved for each symbol on each instance, but it is getting to be a hassle to have to keep updating every single setting manually when I want to change something. Trying to auto set from the server also doesn't work because the server times for products such as ES are still showing that 16:15 is the close instead of 17:00, among other things. A way to quickly update all symbol information across all data connections would be greatly appreciated and I cannot find it in help, thus asking if it even exists. Thank you. |
[2024-01-01 20:01:51] |
Sierra_Chart Engineering - Posts: 17179 |
No this is not supported but refer to: Global Symbol Settings: Direct Editing of Global Symbol Settings through Underlying File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-01 23:59:42] |
