Date/Time: Tue, 26 Nov 2024 04:17:40 +0000
Numbers bars not showing - Chart becomes empty
View Count: 255
[2023-12-31 00:32:22]
AntoineOpala - Posts: 66
I am subscribed to package number 10 and Denali data feed for US stocks.
In Data/trade service settings, Intraday Data Storage Time Unit is set to 1 tick.
In Chart settings, Volume at price multiplier for intraday chart is set to 1.
However, when adding the numbers bars study to a chart, bars become blank.
Do you know why?
I tried this on forex symbols, NASDAQ symbols, __MBO symbols, __-NQTV symbols. All the same.
Sorry for starting this thread, but I could not not find the answer elsewhere in the support board.
If you read this at the very beginning of January, my Denali data feed will not have been renewed yet. But don't worry about this, it will be.
[2023-12-31 07:00:35]
Sierra_Chart Engineering - Posts: 17179
You need to change to Service Package 11. For now we have given you access to the highest service package at no cost for 30 days. After that:
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to.
When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time.
Date Time Of Last Edit: 2023-12-31 07:01:05
