Date/Time: Wed, 27 Nov 2024 04:55:34 +0000
Suggestion: make visible that an alert has been set on a line
View Count: 1055
[2014-07-29 14:06:18]
BataviaTrader - Posts: 63
I was wondering if it's possible to leave a suggestion here.
Say I have drawn a line, and set an alert for that line. However, imho it is handy to you can later on actually see that an alert has been set for that specific line.
For example, add an "A"-sign close to that line somewhere. Would that be an reasonable suggestion?
Thank you in advance for you attenion.
BT
Date Time Of Last Edit: 2014-07-29 14:06:33
[2014-07-29 17:22:10]
Something like this is already supported. Select Tools >> Manage Chart Drawings Window.
Every drawing on the chart will have the text "Alert" in its description in the list of drawings if an alert is enabled on it.
