Date/Time: Mon, 25 Nov 2024 20:31:00 +0000
STANDARDIZE function
View Count: 268
[2023-12-30 23:52:27] |
User411320 - Posts: 289 |
When using the STANDARIZE function , do I still have to calculate the Mean & StandardDev? or does it do it for me based off the value I use it on ?
[2024-01-02 14:09:59] |
John - SC Support - Posts: 36278 |
The function requires that you enter the Mean and Standard Deviation, so yes, you have to calculate these to enter them in the function. The documentation for this is here: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#STANDARDIZE_Function For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-02 19:11:18] |
hello John, Thank you and happy new year.
[2024-01-31 18:46:35] |
Hello, in the following function "STANDARDIZE(X, Mean, StandardDev)", does "X" refer to the length? as in how many bars? |
[2024-01-31 22:52:56] |
"X" is the value for which you want to find the Y value given the Mean and Standard Deviation. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#STANDARDIZE_Function For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
